Author Topic: Live search  (Read 490 times)
Offline Vorlon
Live search
« on: March 18, 2019, 02:04:09 PM »
Right now when you search for a process in the UI the display seems to be static - stats dont update and processes dont appear/disappear if they start/stop while search text is entered.
A live view while searching would be great - Just like Process Hacker.    Or live view default but with a 'freeze' button.
Re: Live search
« Reply #1 on: March 23, 2019, 09:47:11 AM »
This will likely come in time with larger work to the GUI. As you suggest, a pause button will be necessary to smoothly facilitate it.
