Author Topic: CorePrio - Bitsum's 'Dynamic Local Mode'  (Read 4454 times)
« on: November 08, 2018, 03:16:42 PM »
Product home: https://bitsum.com/portfolio/coreprio/
Coreprio package is here: https://bitsum.com/files/corepriosetup.exe
Components:
  • corepriow.exe - GUI, system tray icon is a CPU package
  • cpriosvc.exe - Service container
  • coreprio.exe - Console debug utility, used independently of the service (it will stop the service).
This is very much a work in progress. A one-click updater is included in the package.
« Last Edit: January 01, 2019, 08:11:09 PM by Jeremy Collake »
Re: CorePrio - Bitsum's 'Dynamic Local Mode'
« Reply #1 on: January 01, 2019, 07:51:27 PM »
v0.0.3.6:
 + Cosmetic
 + Remove start menu shortcut to console rendition (coreprio.exe)
« Reply #2 on: January 05, 2019, 03:00:05 AM »
v0.0.3.7:
 + Minor performance and reliability improvements
 + Remove redundant debug output 'managing 0 threads' when DLM disabled
« Reply #3 on: January 07, 2019, 10:39:17 AM »
v0.0.3.8:
 + Fix NUMA Dissociater checkbox would not stay toggled OFF when dialog re-opened
 + Remove warning about use of DLM with NUMA Dissociater. Can be used together. Results will depend on the application load and settings. DLM is not able to do anything positive for benchmarks that utilize all CPU cores since the entire processor is loaded.
(older revision history cleared since it was all early initial dev)
« Reply #4 on: February 06, 2019, 11:00:57 PM »
v0.0.5.1:
+ Add inclusion and exclusion pattern matching by process basename, -l,--inclusions and -x,--exclusions parameters
+ Add inclusion and exclusion control to management GUI
+ When using console app, force Bitsum's DLM to 'On'. Previously enabled only if -f flag for NUMA Dissociater not given
+ Add GUI note that AMD's implementation of DLM, if installed, is disabled
+ Minor other improvements
« Last Edit: February 06, 2019, 11:26:11 PM by Jeremy Collake »
« Reply #5 on: February 11, 2019, 06:14:55 PM »
v0.0.5.2:
+ GUI cosmetic work. Make status control larger and add text indicating settings can't be changed while service is started.
